11_2025_YZ450FSL_DPBSE_US_12_YY_81122.jp
Yamaha just revealed its 2025 line of of motocross, cross-country, off-road and dual-sport bikes for model year 2025. The most dramatically new machine is the YZ250FX cross-country racer, which received the same updates that its motocross sibling did in 2024. Here’s what Yamaha has to say from their official press release:
11_2025_YZ250XS_DPBSE_US_03_YY_08_RGB.jp2025 Yamaha YZ250X two-stroke
Yamaha Motor Corporation, USA is introducing its new lineup of 2025 off-road motorcycles with thrilling options for enthusiasts ranging from young beginning riders to seasoned professionals. The spotlight for 2025 falls on the exciting and ultra-capable new YZ250FX and WR250F. Based closely on Yamaha’s class-dominating YZ250F motocrosser, the new YZ250FX and WR250F are both designed to be slim, light and agile off-road weapons, ready for competition straight out of the box. The YZ250FX includes specific suspension and engine tuning suited to the extreme conditions of cross country racing, while the WR250F is prepped for enduro with unique engine and suspension tuning, an H4 headlight, LED taillight, shortened muffler with spark arrestor and other specific enduro features.
11_2025_YZ250FXS_DPBSE_US_03_YY_08_RGB.j
New 2025 Yamaha YZ250FX
Fresh off claiming last year’s XC2 GNCC title, the new 2025 YZ250FX features an extensive list of enhancements designed to further boost its class-leading performance and capability. With a revamped chassis, updated suspension tune, and reconsidered ergonomics, the new FX is lighter, sharper and more agile, with a better handling feel. Perfect for carving up tight cross country courses.
Updates to the 2025 model begin with a completely redesigned aluminum bilateral beam frame. Based on the competition-proven YZ250F, the new frame provides just the right amount of strength and flex for the perfect balance of stability and cornering performance. The redesign also includes model-specific engine mounts and lightweight subframe. The result is a better handling machine with lightweight feel and increased front wheel traction, allowing the rider to enter corners with greater confidence and more line choices.
Complementing the revised frame, the YZ250FX’s class-leading, fully adjustable KYB® suspension is 10mm shorter and includes updated settings to deliver exceptional balance between handling and bump absorption, along with less pitch on corner entry/exit. The revised frame and suspension settings also result in a lower center of gravity for improved maneuverability in tight, technical terrain and an easier reach to the ground. Additionally, the front fork now includes a new hand-adjustable knob for easy, toolless compression adjustments.
Ergonomics are also enhanced, with a slimmer, flatter, more compact body lending a razor-thin feel and effortless body movement when shifting weight forward and back. The rider triangle is more generous as well with more space between the seat and foot pegs.
Other notable changes for 2025 include a completely redesigned intake system along with optimized ECU settings for better control on the low-end and even more mid- to high-end power. The new FX also receives the next generation of Yamaha’s industry leading Power Tuner App, now even simpler to use with a quick-adjust slide bar for easy engine tuning, and more functionality including new four-level Traction Control. Best of all, it’s still free-of-charge.
11_2025_YZ250FXS_DPBSE_US_07_YY_12_RGB.j
2025 YZ250FX Features & Benefits
• The new YZ250FX is lighter, sharper and more agile than ever, the perfect weapon for dominating cross country competition
• Completely redesigned aluminum bilateral beam frame based on the renowned YZ250F motocrosser provides the perfect balance of straight-line stability and agile cornering performance
• Revised, fully adjustable KYB® coil spring-type fork with speed-sensitive damping now includes hand-adjustable knob for toolless compression adjustment
• Linkage-type rear suspension features a fully adjustable KYB® shock with revised settings for enhanced performance
• Lower center of gravity for enhanced maneuverability and easier reach to the ground in tight, tricky conditions
• A flatter, more narrow body design eases rider movement and updated ergonomics offer increased legroom and more comfort
• Advanced 250cc four-stroke engine features a high-spec piston, aggressive cam profiles and forward positioned intake cylinder head layout for a broad, useable powerband
• More efficient down-draft intake path further boosts mid- to high-rpm engine performance
• Innovative wrap-around exhaust design improves mass centralization and power characteristics
• Ultra-compact 44mm Mikuni® throttle body ensures optimum fuel atomization while saving weight and improving mass-centralization
• Revised Yamaha Power Tuner App is even more user-friendly with intuitive new “Simple Tuning” slide bar, helpful new engine and suspension tuning guides, and additional new features
• New four-level selectable Traction Control System controlled through the Power Tuner App maintains ideal rear wheel traction
• Two-mode adjustable engine mapping allows on-the-fly selection between two maps via new handlebar-mounted push-button switchgear
• Wide-ratio six-speed transmission
• Large 270mm front brake disc and 240mm rear disc are coupled with a Nissin caliper to provide exceptional stopping power and control
• Durable, large-diameter 15-plate cable actuated clutch withstands the high demands of cross country racing
• Lightweight, tapered 1-1/8-inch aluminum handlebars secure to four-position adjustable handlebar mounts
• Wide 55mm foot pegs
• Compact, lightweight push-button electric start provides quick and effortless restarts
• Larger 2.1-gallon fuel capacity (compared to YZ250F) with low-fuel indicator
• Advanced computer-aided wheel design shaves weight without sacrificing durability
• Three-cross-spoke pattern 18-inch rear wheel for improved impact absorption and rider feel
• Race-developed Dunlop® Geomax MX33 tires
• Wired for accessory radiator fan
• Sealed O-ring chain
• Aluminum side stand
• Composite engine guard
• Premium embedded graphics provide excellent durability and scratch resistance
The new 2025 YZ250FX is offered in Team Yamaha Blue and will be available from dealers this October for $9,099 MSRP.
11_2025_WR250FS1_WR450FS1_DPBSE_US_12_YY
New 2025 Yamaha WR250F
Aimed at setting a new benchmark for 250cc enduro performance, the new 2025 WR250F is lighter and slimmer with a lower center of gravity, quicker handling through tight turns, and more confidence inspiring with a host of significant enhancements. The end result is an enduro weapon that’s easy to ride fast, extremely capable in technical situations and more versatile than ever.
Updates for 2025 are also based on the YZ250F motocrosser, starting with a new bilateral beam frame with precisely tuned flex characteristics and unique engine mounts to ensure excellent stability, turning and bump absorption.
The WR250F’s class-leading suspension has been revised and lowered 10mm, contributing to the lower center of gravity for a planted feel and increased ability in tight turns. Fully adjustable KYB® fork with speed-sensitive damping delivers championship-winning performance, and now includes a hand-adjustable knob for easy compression adjustments. Linkage-type rear suspension features a KYB® shock with settings optimized to provide less pitch on corner entry/exit for improved stability.
The seat is now flatter, slimmer, with a more rounded profile, radiator shrouds are two inches narrower, and the fuel tank is slimmer. The new riding position provides more legroom between the seat and pegs, while the bars are moved forward. Altogether, ergonomic enhancements allow for better movement front to rear, easier leg extension, improved seating to standing transitions and a greater feeling of control.
The 2025 WR250F uses the same revolutionary front-intake, rear-exhaust, liquid-cooled, four-stroke power plant as the YZ250F, but tuned for enduro conditions along with an added wide-ratio six-speed transmission for versatility. A new intake design draws air from under the side covers and seat allowing for a more compact body. The more efficient path also boosts mid- to high-rpm engine performance. There is also new four-level Traction Control tuning, lap timer and helpful tuning guides enabled through Yamaha’s groundbreaking next-generation Power Tuner App.
11_2025_WR450FS1_DPBSE_US_03_YY_08_RGB.t2025 Yamaha WR450F
2025 WR250F Features & Benefits
• Lighter, slimmer and sharper with a lower center of gravity, the new 2025 WR250F is built for attacking tight enduro courses
• Completely redesigned aluminum bilateral beam frame based on the YZ250F motocrosser provides the perfect balance of straight-line stability and agile cornering performance
• More efficient intake path further boosts mid- to high-rpm engine performance
• Revised Yamaha Power Tuner App is even more user-friendly with helpful new tuning guides, and additional new features
• Durable, large-diameter 15-plate cable actuated clutch withstands the high demands of enduro racing
• Larger 2.0-gallon fuel capacity (compared to YZ250F) with low-fuel indicator
• Rear wheel comes laced in a three-cross-spoke pattern for improved impact absorption and rider feel
• Radiator fan
• Enduro-specific features including unique engine and suspension tuning, an H4 headlight, LED taillight, shortened, quieter muffler with spark arrestor
The new 2025 WR250F is offered in Team Yamaha Blue and will be available from dealers this October for $9,099 MSRP.
Updated 2025 YZ250F
Recognized as the premier motorcycle in the ultra-competitive four-stroke 250cc class and the current points leader in the 250cc Pro Motocross Championship series, Yamaha’s renowned YZ250F returns for 2025 with a handful of key updates for enhanced performance, comfort and convenience. New features include:
• Revised suspension includes updated rear linkage, new settings front and rear, along with a lighter spring rate on rear shock and new delta-shaped piston shims in the fork for enhanced stability, traction and a more planted front-end feel
• New handlebar switchbox incorporates an updated ribbed design for more practicality and a better look
• New throttle tube increases the spacing between the throttle grip and throttle housing assembly
• New foot peg bracket design is lighter with a revised shape to enhance rider ergonomics
The new 2025 YZ250F is offered in Team Yamaha Blue and will be available from dealers this August for $8,899 MSRP.
11_2025_YZ450FSL_DPBSE_US_03_YY_08_RGB.j2025 Yamaha YZ450F
Updated 2025 YZ450F
The new 2025 YZ450F continues to be the most complete, well-balanced and capable bike in the 450 class. Yamaha’s flagship open-class YZ returns with a handful of key updates for enhanced performance, comfort and convenience. New features include:
• Revised engine mounts complement suspension updates, improving chassis compliance and enhancing stability
• New clutch design increases lubrication and enhances cooling efficiency
• New handlebar switchbox incorporates an updated ribbed design for easier operation and a better look
The new 2025 YZ450F is offered in Team Yamaha Blue and will be available from dealers this August for $9,999 MSRP.
11_2025_YZ250FSL_DPBSE_US_03_YY_08_RGB.j2025 Yamaha YZ250F 11_2025_YZ450FSME_YB_US_06_YY_11_RGB.jpg2025 Yamaha YZ450F Monster Energy Edition
New 2025 Monster Energy® Yamaha Racing Edition YZ125, YZ250, YZ250F & YZ450F
Yamaha brings the look of a full factory ride back for 2025 with the return of the popular Monster Energy® Yamaha Racing Edition YZ125, Monster Energy® Yamaha Racing Edition YZ250, Monster Energy® Yamaha Racing Edition YZ250F and Monster Energy® Yamaha Racing Edition YZ450F. With a sharp, new race-inspired color and graphics package, riders can stand out from the crowd with the livery of Yamaha’s championship-winning Supercross and Motocross teams.
11_2025_YZ125SL_DPBSE_US_03_YY_08_RGB.jp2025 Yamaha YZ125
The new 2025 Monster Energy® Yamaha Racing Edition YZ125 will be available from dealers this October for $7,299; the new 2025 Monster Energy® Yamaha Racing Edition YZ250 will be available from dealers this November for $8,199; the new 2025 Monster Energy® Yamaha Racing Edition YZ250F will be available from dealers this September for $9,099; and the new 2025 Monster Energy® Yamaha Racing Edition YZ450F will be available from dealers this September for $10,199.
Returning 2025 Yamaha YZ Motocross & Cross Country Lineup
The remainder of Yamaha’s 2025 Motocross and Cross Country lineup are available in Team Yamaha Blue with a new YZ graphics package. In addition, the 2025 YZ125, YZ250, YZ125X and YZ250X two-strokes also receive new toolless fork clickers for quick, easy suspension adjustments, an updated radiator shape and a new handlebar pad. The 2025 YZ450FX and WR450F Cross Country models return with a new single-layer seat skin.
The 2025 YZ65 will be available from dealers this month for $4,499;the 2025 YZ85 will be available from dealers this month for $4,999; the 2025 YZ85LW will be available from dealers this month for $5,199; the 2025 YZ125 will be available from dealers this August for $7,099; the 2025 YZ250 will be available from dealers this October for $7,999; the 2025 YZ125X will be available from dealers this September for $7,199; the 2025 YZ250X will be available from dealers this September for $8,099; the 2025 YZ450FX will be available from dealers this month for $10,199; and the 2025 WR450F will be available from dealers this August for $10,199.
11_2025_TTR230S_DPBSE_US_00_YY_0075.jpg2025 Yamaha TTR230
2025 Yamaha Trail Lineup
Yamaha’s capable and fun lineup of rider-friendly Trail models return for 2025 in Team Yamaha Blue with a new YZ-inspired graphics package. The 2025 PW50 will be available from dealers this month for $1,849; the 2025 TT-R50E will be available from dealers this August for $1,899; the 2025 TT-R110E will be available from dealers this August for $2,449; the 2025 TT-R125LE will be available from dealers this August for $3,599; and the 2025 TT-R230 will be available from dealers this month for $4,699.
11_2025_XT250S_RG_US_03_YY_04_RGB.jpg2025 Yamaha XT250
2025 Yamaha Dual Sport Lineup
Yamaha’s world-renowned duo of rock-solid reliable, do-it-all Dual Sport models return unchanged for 2025. The 2025 TW200 is offered in Gallant Gray and will be available from dealers this month for $4,999; and the 2025 XT250 is offered in Radical Gray and will be available from dealers this month for $5,499.
11_2025_TW200S1_MLNM4_US_03_YY_08_RGB.jp2025 Yamaha TW200
The post FIRST LOOK: YAMAHA MX & OFF-ROAD BIKES FOR 2025 appeared first on Dirt Bike Magazine.
