The Can-Am Origin dual-sport bike was officially launched today and is now available for pre-order in the U.S. This is one of two electric motorcycles that were announced about a year ago. The Pulse is the road-going version and both are  powered by a 35kw  liquid-cooled motor. Performance is said to be similar to a 700cc gasoline motorcycle and the range is 90 miles of city riding. Recharge time with a class two charger is 50 minutes to 80%. The price for the standard version is $14,499 and a special edition that pays tribute to the 1973 motocross bikes is $16,499.
Engine
47 HP (35 kW)
Type
ROTAX® E-POWER, Liquid-cooled
Power
47 hp Peak (35 kW) / 27 hp Continuous (20 kW)
Torque
Peak : 53 lbs-ft (72 Nm) from 0 to 4600 RPM
Transmission
Transmission
Clutchless direct drive
Chassis
Front suspension
KYB† 43 mm inverted fork / 10 in. (255 mm)
Rear suspension
KYB HPG shock with adjustable preload, compression and rebound / 10 in (255 mm)
Front brakes
J.Juan† 2 pistons floating caliper, 320 mm disc
Rear brake
J.Juan 1 piston floating caliper, 240 mm disc
Front tires
Dunlop† D605 90/90 R21 (with tube)
Rear tire
Dunlop D605 120/80 R18 (with tube)
Instrumentation
Type
10.25 in. touchscreen display with BRP Connect®
L x W x H
86.8 X 33.9 X 55.7 in. ( 2204 X 861 X 1414 mm)
Wheelbase
59 in (1503 mm)
Seat height
34 in (865 mm)
Ground clearance
10.8 in (274 mm)
Dry weight
412 lbs (187 kg)
Safety and Security
ABS
Anti-lock Braking
Motorcycle Traction control
Coverage
Factory Warranty
2 years vehicle
5 years battery / 31068 miles
Extended Service Terms
Extended Service Terms B.E.S.T. terms available from 12 to 36 months for vehicle excluding battery
The post CAN-AM ORIGIN DUAL-SPORT BIKE OFFICALLY LAUNCHED appeared first on Dirt Bike Magazine.
