624653_MY25_KTM_300_XC-W_FACTORY_EDITION
KTM has officially announced the 2025 300 XC-W Factory Edition based of the same machine that factory rider Trystan Hart has been dominating the AMA U.S. Hard Enduro Series on . The bike features a laundry list of aftermarket parts topped off Red Bull graphics. Below is the official images and information directly from KTM about the limited edition model.
624655_MY25_KTM_300_XC-W_FACTORY_EDITION
Last season saw defending multi-time AMA U.S. Hard Enduro Champion Trystan Hart deliver a perfect season, and in 2024 he has been a picture of consistency on his FMF KTM Factory Racing 300 XC-W, clinching a fourth-consecutive crown. It’s that experience that takes KTM to new heights in the offroad market.
Headlined by its FMF KTM Factory Racing livery, and boasting an insane mix of CNC and anodized hardware, the KTM 300 XC-W FACTORY EDITION is instantly recognizable. And its use of top-specification WP XPLOR PRO suspension elevates the performance even further.
The 48 mm XPLOR PRO 7548 fork is exclusively fitted as standard and represents the pinnacle of enduro suspension, adding a new layer of comfort and adjustability. Tailor-made peak performance and compromise-free offroad dynamics come thanks to WP CONE VALVE technology, with the cone-shaped valve requiring no shim stacks to deliver unmatched damping control and direct response on any terrain. Full adjustability of both compression and rebound damping and spring pre-load is made easy with the provided adjustment tools.
At the rear, the WP XPLOR PDS (Progressive Damping System) shock adopts updated settings on the 2025 KTM 300 XC-W FACTORY EDITION, which further refines the bike’s handling characteristics as a result of an improved pressure balance and a lower risk of cavitation. It will handle the gnarliest of offroad routes, developed to tackle any challenge that you dare to take on.
It features a full-factory wheel set made up of high-strength black D.I.D alloy wheels coupled to orange-anodized, CNC-machined hubs, black spokes, and orange aluminum nipples. Top-performing Dunlop AT82 Enduro tires are fitted, providing exceptional traction in all conditions, while braking duties are covered by front and rear Brembo brake systems, including a floating front disc and solid rear.
An all-new FMF PowerCore 2.1 Titanium Silencer delivers the full power potential of the 300cc TBI 2-stroke engine. Developed for the demands of offroad competition, with a larger body and lightweight titanium construction, this new exhaust offers unmatched 2-stroke progression.
The KTM 300 XC-W FACTORY EDITION has received the ultimate hard enduro treatment, from the standard-fitted radiator fan to the FACTORY racing triple clamp, right down to front and rear disc guards, every element on a FACTORY EDITION is specifically chosen for the job at hand. Plus, chain slider durability has also been increased for 2025.
MY25-KTM-300-XC-W-FACTORY-EDITION-1024x7
KTM 300 XC-W FACTORY EDITION highlights:
  • ORANGE GLOSSY FRAME
  • FACTORY RACING FRAME PROTECTION SET
  • FACTORY RACING SEAT
  • MAP-SELECT SWITCH
  • FACTORY RACING TRIPLE CLAMP
  • FACTORY WHEEL SET
  • RADIATOR FAN
  • SKID PLATE
  • SEMI-FLOATING FRONT BRAKE DISC
  • FRONT BRAKE DISC GUARD
  • SOLID REAR BRAKE DISC
  • WP XPLOR PRO COMPONENTS FRONT FORK
  • REAR BRAKE SAFETY WIRE
  • ORANGE REAR BRAKE DISC GUARD
  • ORANGE SUPERSPROX STEALTH REAR SPROCKET
  • ORANGE OIL FILLER PLUG
  • HINSON OUTER CLUTCH COVER
  • CLUTCH SLAVE CYLINDER PROTECTION
  • FMF TITANIUM POWERCORE 2.1 SILENCER
  • DUNLOP AT82 ENDURO TIRES
624656_MY25_KTM_300_XC-W_FACTORY_EDITION
Just rolling off the Mattighofen production line, the new 2025 KTM 300 XC-W FACTORY EDITION will start arriving this October at authorized KTM dealers. For more information, visit KTM.com.
The post 2025 KTM 300 XC-W FACTORY EDITION : 2-STROKE TUESDAY appeared first on Dirt Bike Magazine.
Регистрация нового пользователя
