MotoFactory Опубликовано 2 июня, 2025 Опубликовано 2 июня, 2025 Sherco has released photos for its 2026 SE300 and SE250 two-stroke models. The bikes will again feature electronic power valves and Keihin 36mm PWK carburetors. Suspension is by KYB and brakes are Brembo. They will also feature hydraulic clutches and six-speed gearboxes. Like the four-stroke models announced last month, the changes for 2026 will strictly be cosmetic. Pricing has not yet been announced, but we understand that a container of 2026 models is already on the water headed stateside. DATA SHEET 250SE/300SE Motor: Single-cylinder 2-stroke engine with Electronic control valve and booster Displacement: 249cc/293cc Bore and stroke: 66.40 x 72.0 mm/72.0 x 72.0 mm Fuel supply: Keihin PWK 36 carburetor Cooling: Liquid cooling with forced circulation Starting: Electric starter Battery: BS Battery 12V 140A Lithium Exhaust: Chromed exhaust pipe, aluminium silencer Transmission: 6-speed transmission Clutch: Hydraulic, multi-disc,oil bath Ignition: 220 W Alternator Chassis: Semi-perimetric high-strength chrome-molybdenum steel Fuel tank: 10 L capacity Brakes: Brembo hydraulic brakes, 260 mm Ø (front) – 220 mm Ø (rear) Front suspension: Closed cartridge KYB fork 48 mm Ø fork legs – 300 mm stroke Rear suspension: KYB 50 shock absorber 18 mm Ø – 330 mm stroke Front wheel: 1.60 x 21’’ black anodized Excel rim, Michelin Enduro Medium tire Rear wheel: 2.15 x 18’’ black anodized Excel rim, Michelin Enduro Medium tire Wheelbase: 1480 mm Ground clearance: 355 mm Saddle height: 950 mm The post SHERCO ANNOUNCES 2026 250 & 300 TWO-STROKES appeared first on Dirt Bike Magazine. Просмотреть полный текст статьи Цитата
