MotoFactory Опубликовано 19 июня, 2025 Опубликовано 19 июня, 2025 Beta has just released another part of its grand plan for 2026. This time, it’s the Xtrainer’s turn in the spotlight. This is traditionally the most affordable European 300cc two-stroke on the market, although 2026 prices have not yet been revealed. The official press release follows. Beta’s 2026 XTrainer retains the popular gray and red color combination, yet the Beta engineering team from Florence, Italy refuses to rest and has added a few updates to this #1 selling entry-level enduro model. For those who have not heard, the XTrainer provides riders with a unique spec list of features geared for performance, ergonomics, and design. Aimed at the entry-level off-road rider looking for more than a low suspension, heavy 4-stroke youth-based bike. The Xtrainer provides a light weight of 218 pounds and has a list of quality components a mile long. The Xtrainer is a purpose-built model, designed from the ground up to deliver an easier and more predictable ride. Not only for beginners, the Xtrainer has found its way into many garages across the world, not only for entry-level, but also for expert riders wanting a play bike as a second model in their fleet. With a lower seat height than traditional full-size off-road models, the narrow mid-section, 15% smaller overall chassis, combined with a 300 cc engine that creates a major amount of torque, the model excels in the toughest conditions. The Xtrainer name has become an icon in the off-road riding world, with the term Rideability being at the forefront of the model’s history. Here is a summary of the model’s features: • Lighter weight: an extremely agile motorcycle, even for novices, a bike that is easier to maneuver at slow speeds and requires less energy from the rider. This enhances the riding experience. • Seat height: 35.8” allows many riders the ability to touch the ground in most situations. • Brakes: Nissin, with discs measuring 260mm at the front and 240mm at the rear. • Battery: lightweight, high-performance lithium battery. • Fork and Single Shock: R16V with 43mm fork tubes at the front and progressive leverage linkage system at the rear. The suspension is fully adjustable, the fork offering adjustable spring pre-load and rebound, and the single shock is adjustable in terms of its spring pre-load, compression and rebound. • Power delivery: smooth and linear, full-bodied and powerful – the perfect mix to have fun everywhere. • Beta Progressive Valve: the Beta Progressive exhaust valve can be adjusted by the rider from an easy external adjuster, allowing engine performance to be effectively adapted to suit every kind of usage. Turn the adjuster inward for slower speeds, turn the adjust out for more free-rev fun. • Map switch mounted on the handlebar: Rain or sun modes, to compliment the progressive valve. • Tank: 2.4 gallon transparent tank. • Automatic oil injection: located beneath the seat (which is easily opened at the touch of a button), it does away with the need for the oil-fuel premix. • Soft tires: soft compound and aggressive design guarantee grip in every situation, the rider benefiting from responses that are less twitchy with respect to a tire with a stiffer carcass. • Cooling fan: The fan is mounted as standard on XTrainer, to ensure the engine always maintains the ideal running temperature, even on slower routes. Thermoswitch controls the fan, so no rider input is needed. • Electric starter: precise and reliable, essential when restarting the bike in tricky situations. • Engine and clutch: derived from the RR model range, no corners are cut with the Xtrainer, a diaphragm clutch along with a six-speed transmission complete the package. 2026 Model Updates: • Taillight: XTrainer gets a new LED taillight, more modern and sturdier than the previous model. • Meter: the 2026 model is equipped with a new meter, which is larger and easier to read. This new meter provides the rider with much information such as speed, distance, trip meter, and low oil warning. • Engine: New crankcases house larger main bearings for better durability. • Transmission ratios: first introduced in the RR X-Pro, second gear was significantly updated to provide a wider range of use. This has improved the transition between second and third gear. • Graphics: the plastic retains the beloved Grey color, updated with modern and vibrant graphics, and contemporary white finishes that stand out and embrace its character. Availability August SPECIFICATIONS Type: Beta Built single cylinder, 2-stroke, liquid cooled, with BPV power valve system and counter balancer, electric start with back-up kick starter sold as an option Frame: Molybdenum steel / Parameter-style w/ quick air filter access Wheelbase: 57.75″ Seat Height: 35.8″ Bore: 73mm Ground Clearance: 12.6″ Stroke: 69.9mm Footrest Height: 15.4″ Displacement: 292.3cc Dry Weight: 218 lbs (wet weight, no fuel) Compression Ratio: 11.55:1 Fuel Tank Capacity: 2.3 US Gallons Exhaust Valve: Beta Progressive Valve (BPV) Front Suspension: 43 mm inverted front fork with adjustable dampening Ignition: AC-CDI Kokusan Spark Plug: NGK GR7CI8 Rear Suspension: Steel body shock with adjustable rebound and compression Lubrication: Electronic Oil Injection Oil Tank Capacity: 650cc Front Wheel Travel: 10.6″ Carburetor: Keihin PWK 36mm Rear Wheel Travelv10.6″ Clutch: Wet Diaphragm-style Front Brake: 260 mm floating rotor Transmission: 6 Speed Rear Brake: 240 mm rotor Final Drive: O-ring chain Front/Rear Rim: 21″ (Front) 18″ (Rear) Front/Rear Tire: Soft Enduro Competition The post BETA RELEASES 2026 XTRAINER TWO-STROKE appeared first on Dirt Bike Magazine. Просмотреть полный текст статьи Цитата
