BETA REVEALS 2026 RACE MODELS AND PROMISES TO EAT THE TARIFF
Beta has revealed its RR Race  Models for 2026. This includes four two-strokes (125, 200, 250 & 300) and four four-strokes (350, 390, 430 & 480). The Race Models are step up from the previously announced X-Pro models, and include KYB suspension and a long list of upgrades. Beta has also revealed pricing, and unlike other manufacturers, will not have an additional charge for tariffs–that expense has been rolled into the MSRP. The official press release follows:
Beta is announcing the arrival of the new 2026 RR Race models a little early for the season. This is an early rollout compared to the traditional October launch, which usually marks the arrival of the best-performing bikes from the Tuscan company, reflecting its constant commitment to innovation and attention to detail, to offer increasingly advanced and performance-based models to riders of all abilities.
RR Race models represent the race versions of Beta’s Enduro models, characterized by a series of modifications to the engine, suspension, frame, and equipment, making the bikes ideal for giving their best performance on the track – always in the sign of RideAbility.
Take a look at all the new features and characteristics that set the 2026 models apart.
RR-Race-125-2T-My26USALOWRES-1024x633.jp
The 2026 125 RR Race
Features–125 & 200 RR Race:
Both 125 and 200 receive updated gearboxes to improve durability and provide smoother shifting at the same time. This new system includes updates to the shifting system as well to further improve the overall gearbox’s performance.
RR-Race-300-2T-My26-USALowres-1024x692.j
250 & 300 RR Race:
In line with the recent innovations introduced on the 2026 RR X-PRO range – widely appreciated by amateurs and experienced users alike – the engine of the new RR Race 250 2-Stroke has been completely redesigned in search of a greater amount of torque and a broader power delivery at all speeds, to be enjoyed by all riders in any riding conditions. What has changed specifically:
» Crankshaft and cylinder: now shared with the 300 model. The stroke was reduced compared to the past (from 72 mm to 69.9 mm), and consequently, the bore was increased (from 66 mm to 67.4 mm) to maintain a full 250 cc. The cylinder’s transfer port geometry was redesigned and now houses a new dedicated piston.
» New cylinder head: combustion chamber has been entirely redesigned to create the ideal operating conditions with the new engine geometry, while still using the double spark plug.
The Twin Plug cylinder head (both on 250 and 300) brings numerous benefits:
» It offers a better distribution of spark ignition inside the combustion chamber, which improves overall power delivery while reducing unburned gases.
» The engine’s range of use is further extended, as both greater torque and more power are available.
» The two spark plugs are managed with a separate electrical system. This means that, if one of the spark plugs should burn out, the engine will still be able to run, although with less efficiency, allowing the race or off-road session to be completed.
With these updates, the torque and linear power delivery were significantly increased, without affecting the overall performance, and also improving the motorcycle’s handling, with centralized weight and lowered center of gravity. The crankcase houses larger and stronger main bearings for both the 250 and 300 engines.
» Gearbox: The 250 and 300 have a longer range second gear to improve the range of power in most sections. This update has improved the overall use while in second and third gear for most woods riding.
RR-Race-350-4T-My26-USALOWRES-1024x633.j
350 / 390 / 430 / 480 Four Stroke RR Race:
All 4-stroke engines received new maps with respect to the previous Model Year, to improve their delivery along the entire range. Whatever the displacement, Beta engineers optimized their linearity and usability of the propellers to better manage the power available. This constant improvement of the mapping enhances the bike’s performance from the bottom to the top end.
All of the Race models receive a new rear brake hose routing system.
Racing Components – Entire Range
The tried and tested suspension package and the special components of Beta’s race-ready version are confirmed:
» 48 mm Kayaba (KYB) AOS close cartridge fork: anodized internal parts and the treatments administered to the materials minimize sliding friction, while adjustable compression and rebound damping let each rider find the perfect customization of the setting.
» Kayaba (KYB) 46mm Shock: the KYB Monoshock can be considered a benchmark in the racing context for its capacity to absorb the roughness of the terrain, the level of traction transferred to the rear wheel, and the consistency of performance, even in particularly heavy use. The hydraulic setting can be fully customized by adjusting the external compression (both high and low speed) and rebound settings.
» Front axle: immediately recognizable by the red anodized alloy release lever, this component is crucial for saving precious seconds in a race when you need to change a tire.
» Reinforced handguards: the handguards feature a two-component material mold, and not only give the bike a racing look but also make them especially hard-wearing in even the roughest off-road use.
» Machined alloy footpegs: to ensure maximum control at all times and no loss of contact with the bike, the footpegs have interchangeable steel pins; these are narrower than in the past to facilitate movement of feet, but better in terms of grip.
» Rear sprocket with anodized aluminum core and steel teeth by ZF SPROCKETS: top-class performance, lightness, and strength – the perfect mix of all the attributes any racing component must have.
» Dedicated race seat: with non-slip upholstery and document holder pocket for unparalleled grip, comfort, and practicality.
» Racing graphics: to never go unnoticed on the race field.
» Anodized black gear lever and rear brake pedal.
» Gearbox oil filler cap, engine oil filler cap, and oil filter cap are anodized red aluminum.
» Chain tensioners in red machined alloy.
On all two-stroke models, Beta has decided to stick with its choice of doing away with an oil injector in order to minimize the weight of the bike.
Availability: October
Pricing:
125 RR Race: $9,890.00
200 RR Race: $10,790.00
250 RR Race: $11,390.00
300 RR Race: $11,590.00
350 RR Race: $11,990.00
390 RR Race: $12,190.00
430 RR Race: $12,390.00
480 RR Race: $12,590.00
*plus a $529.00 destination fee
Not included are professional dealer setup, taxes, license, or other required fees
No tariff surcharges
The post BETA REVEALS 2026 RACE MODELS AND PROMISES TO EAT THE TARIFF appeared first on Dirt Bike Magazine.
