At one time the British Empire consumed 20 percent of the inhabited land mass on earth. We’re not pointing fingers, but it kinda looks like Triumph is quietly attempting to recreate that empire in the motorcycle world. The 2026 Triumph TF450-E marks the first expansion into the only two-wheel segment where Triumph had previously laid no claim—enduro. It will be imported as an off-road competition bike in the U.S. The 450 will have a 250cc little brother in that category, and there’s no hiding the fact that a dual-sport line is in the works. In the European Union, those models are already being sold with full Euro 5 compliance. They will have the option of competition kits to bring them up to the same state of tune as the U.S. dirt-only models.
Triumph is still a long way from becoming a world-dominating empire, but they have established colonies outside of Great Britain. The TF450-E is assembled in a Triumph-owned-and-operated factory in Thailand. It comes out of the same plant as the TF450-RC and the TF250-X motocross bikes. According to Triumph, the bike could be made in any of the company’s five global factories with no change in quality.
Triumph has equipped the TF450-E with more goodies than most off-road competition bikes, including a radiator fan, instruments, lights and a horn. Yes, a horn.
BASE ELEMENTS
Don’t let the headlight fool you. The U.S. version of the TF450-E is a race bike based on the 450 motocrosser introduced last year. If you want to slot it into a category, it belongs in the same class as the Honda CRF450RX, Yamaha YZ450FX, Kawasaki KX450X and KTM 450XC-F. Most of those bikes are a hair’s width away from being motocross bikes. The TF450-E is farther removed from its motocross roots than any of them, but it still makes enough sheer power that it would be right at home on a track. It’s simply a different kind of power. The motor uses a full-circle crank with 30 percent more inertia. The cam is different, the mapping is different and the pipe is different. The piston, valve size, compression ratio and combustion chamber, though, are essentially the same, but it has a six-speed gearbox. In the chassis department, the biggest departure from the MX bike is the swingarm, which is 10mm longer. Then, there are all the off-road specs that we have come to expect: softer suspension settings, an 18-inch rear wheel, increased fuel capacity, a kickstand and so forth. Two items that you don’t often see in this category are the 1450-lumen headlight and the radiator fan. Those features are more commonly seen on trail bikes. The bike also has a small odometer and, of all things, a horn.
Usually, a headlight indicates that a bike is meant for trail riding. In this case, the TF450-E is a full-blooded racer, one that can be raced at night.
If you don’t know much about the underlying motocross version, that’s understandable. That bike is still quite rare in the U.S. and hasn’t yet made a debut in AMA Pro Motocross. The motor uses a single-overhead-cam layout with a Dellorto throttle body, a Keihin injector and Athena software. The frame is aluminum with a central backbone, the suspension components are KYB and the brakes are Brembo, as is the hydraulic clutch. There are no re-invented wheels here. Triumph engineers say they looked at existing products in the dirt world and cherry-picked the features and components they liked best.
Overall suspension setup for the Triumph’s KYB components is soft enough for trail riding, but it can be adapted for racing.
MEET US IN THE HIGH DESERT
Triumph decided to give the U.S. press its first taste of the bike at a mass introduction in the high-desert area of Southern California. At first that struck us as weird; there are no deserts in the British Isles. After riding the bike, we understood. The TF450-E is made with that terrain in mind, such as wide-open spaces, steep hills and deep sand. All that stuff demands lots and lots of power, and the TF450-E is a fast motorcycle. The engineers claim it has a peak output of 58 horsepower, which sounds about right. Most 450 motocross bikes are in that same vicinity, and the new Triumph feels like it’s very close. It is, perhaps, a little softer and smoother down low than most, but it builds power fast and hard in the middle. Then, on top, it tapers off quickly. If you have a notion to hold it open and delay your next shift, the rev limiter steps in and forces the issue. Having a ton of power delivered in a short range means that you shift quickly and don’t spend much time in each gear. The result is that you end up going faster than you realize.
The basic motor platform is the same as the motocross version, but the E-model has a six-speed gearbox, a different cam, a full-circle crank and new mapping.
You can chill out and slow things down if you want to, though. It’s a trust issue. With other bikes that make this kind of power, you don’t dare let the revs drop for fear of stalling. It turns out that the Triumph is relatively reluctant to stall, even at very low revs. It also runs surprisingly cool. Virtually all of the other competition 450s will boil over and flame out if you spend too much time in slow terrain. The TF450-E doesn’t care how slow you go or how long you do it. The fan automatically turns itself on and off as needed.
Triumph still features a number of choices that make more sense in Europe, such as the short-knob Michelin tires and the self-folding kickstand.
STABLE MABLE
Back in the August 2025 issue we tested the TF450-RC motocross bike and proclaimed it one of the most stable bikes in the motocross world. We loved it, and all the time we were thinking about what a great off-road platform it would be. Most current motocross bikes have migrated towards quick-steering characteristics and have dragged off-road bikes in the same direction. The TF450-E is just what we expected; it has great straight-line stability. That might sound like code for a bike that doesn’t turn well, but the opposite is true. In the rocky, sandy and sketchy soil conditions that define off-road riding, you need a secure, well-planted feel above all, and that’s what the TF450-E gives you. It tracks well and goes where it’s pointed. It does feel like a big, long motorcycle, but that’s not surprising. The wheelbase is, after all, longer than that of the motocross bike, it does have a bigger tank and it is heavier. None of those issues are unusual in the off-road world.
And, as is always the case with off-road bikes, Triumph had to blindly choose a path for suspension setup. They can’t know where the bike will be used, so they were forced to make a guess. In this case, the TF450-E landed a little on the soft side of the average closed-course off-road bike. The front end, in particular, is set up to favor comfort rather than speed. It’s excellent in rocks, but can dive when the speeds increase. We didn’t want to lose the stability that we loved so much, so we leveled the bike out by lowering the rear end, eventually landing around 108mm of sag. Overall suspension action was great at everything up to full-race speed. In our experience, racers are more likely to rework their suspension than trail riders, so Triumph’s decision makes perfect sense.
The TF450-E now has an MSRP of $10,795. There’s no word on how it will be affected by proposed tariffs.
SHORT TIMER
We only had one day of riding, so there’s more to learn about the new Triumph. It comes with all the same electronic functions as the motocross bike, including launch assist, traction control, Quickshift and multiple maps. We quickly learned we liked the most aggressive map and didn’t have time to test the other functions. Will off-road riders use launch assist? Maybe, maybe not. It can’t hurt to have it available. As for Quickshift, past testing has revealed a wide range of opinions; some of them very passionate, pros and cons. The good news is that the E-model shifts much more easily than the motocross bike. Rumor has it that there will be an update for the MX bike soon.
Triumph has promised a long-term test bike soon. Stay tuned, because there’s a lot more to unpack here as the Triumph empire expands.
The TF250-E is the surprise performer in the new Triumph off-road line. The MSRP is $9795.
TRIUMPH TF250-E
Little brother gets a head start
Triumph officially revealed the TF250-E at the same time as the TF450-E, but in truth, the smaller bike was already a step ahead. For the last year, Jonny Walker has been racing a modified TF250-X motocross bike in off-road events all over the world. Plus, Ricky Russell currently sits in third in the AMA National Enduro Championship standings on a private TF250-X effort.
At the official rollout of the new off-road line, the 450 overshadowed the 250, but the word spread quickly. The 250 was a better match to the high-desert terrain of the introduction. That might fly in the face of conventional thought; you would expect large displacement to be a key ingredient for desert. What made the 250 so effective was the fact that it revs forever on top and has surprising torque on the bottom. You put that together, and you have an effective powerband that’s 6000 rpm wide and you never have to shift!
Jonny Walker won the fourth round of the 2024 EnduroCross Championship on a Triumph 250, then was second overall in the FIM SuperEnduro Championship.
There are different personalities throughout the rev range. On the bottom, it has a very smooth nature, which is perfect in low-traction situations. In the middle, it can deal with hills and sudden surprises, and on top it’s in full-race mode. Oddly enough, the 250 was capable of climbing all the same hills as the 450. Traction was the limiting factor, and the 250 was capable of finding it.
In overall handling, the two bikes demonstrated what we have often seen—the 250 felt far lighter. Triumph’s official specs say there’s only 5.5 pounds between the two, but the increased rotational mass and horsepower always add to the sensation of weight.
One big question remains unanswered: will there be another sibling? Triumph’s ambition to take on KTM is obvious, and the 350 category is a ripe target. One way or another, we’re sure that the Brits have more in store.
The post OFF-ROAD IMPRESSION: ALL-NEW 2026 TRIUMPH TF450-E appeared first on Dirt Bike Magazine.
