MotoFactory Опубликовано 22 декабря, 2025 Опубликовано 22 декабря, 2025 Success is a burden. The Kawasaki KX250 has a legacy of winning. It goes back to the early years of 250 four-strokes when names like Ryan Villopoto, Grant Langston, and Adam Cianciarulo were synonymous with Kawasaki and victory. In recent years, however, wins at the pro level have been fewer and farther between. Is it the bike? Is it the team? Is it the riders? No, no and no. Racing is, at best, unpredictable and, at worst, a game of chance. The 2026 Kawasaki KX250 remains one of the fastest and most sophisticated 250s in the motocross world. It’s simply a victim of lofty expectations born from great success. Kawasaki has a history of winning the 250 class at the pro level. The latest KX250 is built on the success of the ones that came before it. TECH INSPECTION If you go back to 2019, the KX250 was a product of a completely different era. It had no electric starter, it had an enduro-like power delivery, and the Monster Energy Pro Circuit team had to work subtle miracles to keep it in the winner’s circle. Then began a step-by-step evolution process. A new top end and a big increase in peak power came in 2020. Electric start came in 2021. A complete redesign happened last year. Along the way, the KX has become more and more sophisticated with features like a Nissin hydraulic clutch (still very rare in a Japanese 250) and Bluetooth engine tuning through the Rideology smartphone app. For 2026, there are no mechanical changes for the KX250. That’s understandable considering how much change came in 2025. It got all the changes that the KX450 received a year earlier, including an intake that brings air over the top of the shock. Within the motor, it got a new head with center exhaust port and a long list of new parts, including cams, piston and even the spark plug. The chassis got Showa suspension, which ends a five-year stint with KYB. The KX also gained weight. It now hits the official Dirt Bike digital scale at 232 pounds without fuel. That makes it the heaviest of the 250s, if only by a few pounds. In peak power, the Kawasaki KX250 remains near the top of a very competitive class. CLEAN & GREEN We used to say that power was disproportionately important in the 250 class. Now, we have to modify that somewhat; a lack of power can be crucial. The Kawasaki KX250 does not lack power. It’s within a horsepower or two of being the fastest bike in the class, which is perennially something powered by a KTM motor. The problem is that almost all of the current 250 four-strokes are within a horsepower or two of being the fastest in the class. So, it’s all about how that power is delivered and how easily it can be turned into quick lap times. There are no mechanical changes for the 2026 KX250. The MSRP is $9099. That does not include tariff, destination or local fees. Last year, Kawasaki tried to broaden the power curve. After all, everyone traditionally seems to like the Yamaha YZ250F despite it having slightly less peak power than the others. On top, the KX is still the most powerful of the 250s from Japan, but whether or not it matches the universal appeal of the Yamaha power delivery is debatable. On the Kawasaki, you have to be very aggressive with the throttle. Never open it halfway; hit the stop and stretch the cable. If you play by those rules, the Kawasaki flies around the track. The clutch makes the job easier, because it has a preposterously light pull. It might even be so light that it encourages clutch abuse. Last year, the KX250 got all the changes that the 450 received in 2024. That includes the new frame and bodywork. We went looking for a little more throttle response with the Rideology app and had some success. This is similar to the Yamaha Power Tuner, but functions with Bluetooth rather than Wi-Fi. Just like the Yamaha, you are allowed to alter spark advance and fuel mixture at different rpm levels and throttle openings. Just to make things simple, we leaned out the fuel mixture (-3) across the board at all throttle openings above 40 percent. Then we advanced the spark (+3) at all throttle openings below 30 percent. In the end, we succeeded somewhat in giving the KX a little sharper response. But, we have to say that the stock mapping is hard to improve without changing other factors. If you were to open up the airbox and install an aftermarket pipe, that’s where you can really make gains with mapping. Pro Circuit is all in with changes that up the performance of the KX. They are currently offering a kit in cooperation with Kawasaki to bring the performance to the next level. The KX now allows you to tune the motor via Bluetooth. Unlike some other manufacturers, Kawasaki doesn’t make you pay extra for the connectivity unit. SHOWA ME THE WAY The Kawasaki KX250 and KX450 have never shared so much technology. Now, the suspension components are even the same; only the spring rates and valving vary. With the move to Showa, the KX250 made a noticeable improvement in its overall ride. That isn’t to say the previous KYB components were inferior; they were just oddly stiff. Now, the bike is more in line with a typical 250 rider. It’s well balanced and seems to get better and better the harder you ride. Here’s where we admit that most of our test riders are either too heavy or too stinkin’ fast to fall into the proper demographics for the typical 250. Sean Lipanovich is around 150 pounds and rides full speed all the time. Mark Tilley is around 180 pounds and a little more conservative. Both riders loved the stock settings, which tells us that the bike might still be stiff for the 250 class. Or, maybe the KX has hit on the magic formula to please everyone with only a few changes in damping. Both riders prefer the rear sag around 104mm. With last year’s chassis redesign came a little sharper turning manners. The previous KX was a bit of a throwback to an earlier time. It was the most stable bike in the class, but it took a little more effort to bend through a corner than most modern bikes. Now, the KX is more responsive to subtle input. It’s still among the most stable bikes in the motocross world, but the changes of 2025 took it a half step towards Supercross-style handling. The exhaust canister was moved forward 50mm last year to centralize mass. EVOLUTION OF THE BREED You gotta love Kawasaki’s philosophy when it comes to chassis adjustment. It’s the only bike in the class that offers two footpeg locations. The pegs come mounted in the high position, but most riders like the low position better. That also offers a touch more space between the pegs and the foot controls. The handlebar pedestals are reversible and can be located in either of two different mounting holes, giving the bike four possible bar locations. In overall quality of bits and pieces, Kawasaki is working to clean up some of its past weaknesses. The hard plastic grips are gone, now replaced with ODI lock-ons. The air filter is much easier to access, but has comparatively little surface area, so it should be serviced often. While we’re complaining, the exhaust note is still a little raspy. And, some of the fasteners aren’t great. You’ll have to pick the captured rear-fender/seat nut off the floor every time you remove the seat. On the other hand, the Dunlop MX32 tires are excellent. So are the Nissin brakes, and even the quality of the chain and various bits and pieces. Is all that enough to allow Kawasaki to keep its place of esteem in the 250 class? Absolutely. Overall, we have to say that the current Kawasaki KX250 is a motorcycle worthy of its legacy. The 250 motocross world remains a hotbed of wildly competitive products, and the Kawasaki KX250 remains near the front—right where it’s expected to be. The post 2026 KAWASAKI KX250: FULL TEST appeared first on Dirt Bike Magazine. Просмотреть полный текст статьи Цитата
