MotoFactory Опубликовано 13 декабря, 2025 Опубликовано 13 декабря, 2025 Dirt Bike Holiday Gift Guide: Top Gear for Every Rider The Dirt Bike Magazine staff knows that it can be difficult to find that perfect gift for the two-wheeled fanatic in your family. So, for the 2025 holiday season, we teamed up with popular powersports-industry companies to compile a list of possible gifts to help you find something perfect for that special enthusiast on your list. DENAGO POWERSPORTS MX & MX1 Designed to deliver authentic riding experiences without needing to operate a manual clutch, the MX model uses a fully automatic transmission, while the MX1 model has an auto clutch with a four-speed gearbox. Both feature electric starting, disc brakes, adjustable suspension and keyed ignition, and are powered by reliable 107cc OHC engines backed by six-month parts-and-labor warranties. Color-matched CNC-aluminum brake-reservoir caps, chain-adjuster blocks and folding/adjustable levers are standouts in this class. Six colorways are available. Price: $749–$899Contact: www.denagopowersports.com MX-TECH COMPLETE SUSPENSION MX-Tech is a small company of motorcycle enthusiasts based in the USA that was born out of a passion to make suspension safer and more durable with precision tuning capabilities. The MX-Tech premium setup features the National shock with 49mm complete forks available in two uniquely different versions of closed-chamber cartridges. The Blackjack is for SX and MX, and the Raven is for hard enduro and enduro; either version can be used for off-road depending on your settings. The National shock is a true performance shock. The adjusters are very responsive, they include Ti hardware, are low friction and easy to service. The body tube and reservoir are both Kashima-coated, while the oversized shock shaft is DLC-coated. A mechanical preload adjuster is also available. Price: $6939Contact: www.mx-tech.com ASV HOLIDAY PRO PACK ASV Inventions is proud to announce the return of its legendary Holiday Pro Pack, available exclusively through participating brick-and-mortar dealers this holiday season. The Pro Pack includes a forged-aluminum brake and Pro-model clutch lever that features an ASV-designed Pro perch with ASV rotator clamp, dust cover, on-the-fly cable quick adjust and sealed bearings at the perch pivot point. Price: $225Contact: www.asvinventions.com EXCEL ONE RIMS Excel One rims were developed for enthusiasts and weekend warriors looking for a good value. Ideal as OEM replacement rims, Excel One is an economical alternative to premium Takasago and Excel A60 rims. Available in 21×1.60, 19×1.85 and 19×2.15 sizes. Price: Starting at $129.95Contact: www.rkexcelamerica.com ARAI HELMET VX-PRO4 Arai’s VX-Pro4 is designed for MX, enduro and off-road use. Just as in every Arai helmet, the basic and simple organic shell shape is based on the R75 shape concept—a visual demonstration of Arai’s commitment to maintaining shell integrity and real-world impact performance. Price: $759.95Contact: www.araiamericas.com TWIN AIR MAINTENANCE KIT Keep your air filter clean and you’ll keep your engine running at top power and lasting longer. The Twin Air system is the solution. This kit includes everything you need in a sturdy storage box with carrying handles—cleaning tub, oiling tub, dirt remover, liquid power filter oil and Twin Air contact cleaner. Price: $135.95Contact: www.dominuscorp.com HYPERLITE FULL-COVERAGE SKID PLATE Designed to bolt directly onto 2019–2025 Honda CRF250F air-cooled models using OEM hardware, the Hyperlite full-coverage skid plate with linkage protection is constructed from 5mm-thick high-strength plastic and weighs just 1.5 pounds. Available in both red and black at no extra cost. Price: $59.95Contact: www.hyperlitemoto.com KAYO MOTORCYCLES Kayo pit bikes and dirt bikes make a perfect holiday gift for riders of all ages. With models ranging from 60cc up to 250cc, there is a Kayo designed for every skill level. All Kayo pit bikes feature off-road-specific knobby tires, electrics-start four-stroke engines, hydraulic brakes and frame-mounted kickstands. Kayo’s focus is to build affordable, reliable products people can have fun on. Price: Starting at $1099Contact: www.ridekayo.com BOLT MOTORCYCLE HARDWARE TRACK PACK Available in universal or model-specific arrangements, Bolt Track Packs are designed to contain the hardware riders need and replace most often. Each kit contains M5, M6 and M8 flange bolts, flange nuts, metal locking nuts, T-nuts, washers and screws in a convenient plastic carrying case. Designed for Japanese and European MX and off-road bikes. Price: Starting at $16.99Contact: www.boltmotorcyclehardware.com MOTION PRO TI COMBO DRIVE T-HANDLE Constructed using a titanium-alloy shaft and handle that are precision TIG-welded for durability, the Motion Pro combo drive T-handle features two 1/4-inch drives with a 44 lb-ft torque rating and one 3/8-inch drive with a 48 lb-ft rating. It’s ideal for bodywork hardware, triple-clamp pinch bolts and control adjustments. Price: $99.99Contact: www.motionpro.com BARNETT DIRT DIGGER CLUTCH Barnett Dirt Digger high-performance clutch kits feature clutch plates made with Barnett’s exclusive carbon-based C22 or Kevlar K22 friction material, tempered-steel drive plates and heavy-duty springs. Dirt Digger kits are designed for stronger, more positive engagement and more oil flow for increased clutch life. Price: Starting at $100 Contact: www.barnettclutches.com KOVE 450 RALLY Designed from the ground up to be lightweight, agile and off-road-capable, the Kove 450 Rally Pro is rally-bred, not just rally-inspired. Features include a 449cc DOHC fuel-injected engine, steel semi-perimeter frame, three separate fuel tanks, tool-less air-filter access, high-intensity LED headlights, aggressive knobbies and fully adjustable Yu-An suspension. Price: $9499Contact: www.kovemotousa.com B’LASTER PRODUCTS B’laster’s new line of Power products is designed to keep your bike running great and looking good. Chain cleaner and lube use B’laster’s ProStraw with Control Flow Technology for precise application. Air-filter cleaner and oil help stop dust and dirt from ruining your engine. Mud B’laster makes washing easy—spray it on and watch mud drip away. Finish with Factory Shine to bring plastics back to life. Price: $10.99 and upContact: www.blasterproducts.com MAXIMA PRO PLUS FOUR-STROKE OIL Pro Plus+ is a full-synthetic, ester-fortified four-stroke engine oil designed to deliver superior protection at any temperature—from cold starts to race heats. It offers excellent clutch feel and unmatched clutch protection. The shear-stable formula maintains viscosity under extreme stress, while advanced additives minimize oxidation and wear. It exceeds API SN Plus and JASO MA2 standards. Price: $15.99 (10W-30 and 10W-40), 33.8 ouncesContact: Your local dealer or www.maximausa.com TWISTED ENGINEERING HANDLEBARS Made in the USA, the Twisted Engineering Composi-Flex handlebar is designed to flex in all directions, helping reduce arm pump, fatigue and blisters while absorbing shock and vibration without added weight. Durable construction prevents breakage in a crash and uses no external parts that wear out. Available in four flex levels and three popular bends. Price: $499Contact: www.twistedengineering.com GIANT LOOP ZIGZAG HANDLEBAR BAG Giant Loop’s smallest bag, the Zigzag handlebar bag, works like a dirt bike glove box. It’s ideal for carrying a wallet, phone, registration/insurance cards and other small essentials. Made of military-spec materials, it includes an internal mesh zippered pocket and offers 1.5 liters of storage. Backed by a limited lifetime warranty. Price: $55Contact: www.giantloopmoto.com MOTOREX OIL CHANGE KIT Motorex all-in-one oil change kits for Honda, Yamaha and Kawasaki four-strokes conveniently include a high-quality oil filter, OEM-spec crush washer or O-ring, and the exact amount of oil for each application. Each kit comes with JASO MA2-rated fully synthetic engine oil. Take the guesswork out of oil changes. Price: $29.00Contact: www.motorexusa.com USWE OUTLANDER MOTO 4L The Outlander Moto 4L is the slim king of USWE hydration packs. It carries a 3-liter (100-ounce) Elite hydration bladder with Slide-Seal top and features USWE’s patented No Dancing Monkey four-point harness for a 100-percent bounce-free fit. The stretchy harness allows a tight fit while still letting you breathe and move freely. Price: $129.99Contact: www.uswe.com MITAS TERRA FORCE-MX SM Designed specifically for motocross, the Mitas Terra Force-MX SM front and rear tires feature a tread and carcass tuned for soft-to-intermediate terrain. The Terra Force-MX line is the result of MXGP and U.S. Supercross development. Also available in 50cc, 65cc, 85cc and Supermini sizes. Price: $54.95 and upContact: www.mitas-moto.com NITROMOUSSE PLUSHIE FOAM INSERT The Nitromousse Plushie foam insert is specifically made for slow, tight, technical extreme-enduro riding. It’s designed to mimic the feel of a tube at 6–8 psi while being completely flat-proof. Top pros like Cody Webb, Destry Abbott, Cooper Abbott and Quinn Wentzel rely on them. Price: $134.95 each (includes one tube of Nitrolube)Contact: www.nitromousse.com KOVE 800X RALLY The new Kove 800X Rally is an adventure bike designed to feel more like a roost-throwing dirt bike than a road-focused ADV machine. It features a 799cc DOHC parallel-twin engine making 95 horsepower and a curb weight of only 364 pounds—70–100 pounds lighter than most competitors. It has a 5-gallon tank, ABS and Yu-An suspension components tuned for the 800. Price: $12,999Contact: www.kovemotousa.com SEAT CONCEPTS ELEMENT COMPLETE SEAT The Element seat provides all the benefits of Seat Concepts’ Comfort line with added perks. Four traction ribs at the rear keep you firmly planted, and the cover is made entirely from gripper material. Each seat is seam-sealed internally and uses a water barrier on the foam to keep moisture out. Price: $359.99 and upContact: www.seatconcepts.com SCORPION EXO XT9000 The Scorpion EXO XT9000 offers exceptional visibility and lightweight comfort in a hand-crafted 3K carbon-fiber shell designed for superior strength and impact dispersal. Available in gloss or matte finish and multiple graphic options. Shown with an optional Ruby mirrored shield. Price: $554.95Contact: www.scorpionexo.com ALUMA TANDEM AXLE TRAILERS With an 81×192-inch bed, the 8016 tandem-axle trailer from Aluma offers plenty of room for hauling. Built for wider loads, it features a 75.5×60-inch bi-fold tailgate and removable fenders. Fender steps, tongue handle and receptacle holder are standard. Price: $10,373Contact: www.alumaklm.com MX CHAMP A90 CARBON MATRIX WHEELSETS MX Champ A90 Carbon Matrix wheelsets are designed as OEM replacements in a variety of color combinations for most popular MX and off-road models. Each set uses aircraft-quality aluminum that is heat-treated for durability, 6061-T6 hubs with five-axis CNC machining, NSK bearings, wheel spacers, stainless spokes and 7075 heat-treated aluminum nipples. Price: $849.95Contact: www.mxchampusashop.com FMF TURBINECORE 2.1 The FMF TurbineCore 2.1 uses the exclusive Turbine Dampening System and is USFS-legal for two-strokes. Its straight-through spark-arrestor canister design and stainless-steel end cap deliver strength, durability and track-/trail-proven performance. It’s the number-one spark arrestor in the world. Price: $269.99Contact: www.fmfracing.com MOOSE RACING GOGGLES Moose XCR goggles keep your vision sharp with anti-fog, scratch-resistant lenses and a wide viewing port. A ventilated frame, moisture-blocking seal and removable nose guard protect against dirt and sweat. Available in four colors and supplied with both tinted and clear lenses. Price: $39.99Contact: www.moose-offroad.com KOVE MX250 The Kove MX250 balances affordability and performance so riders don’t have to spend a fortune to have fun. The DOHC, 249cc fuel-injected engine offers multiple EFI maps and delivers 37.5 horsepower through a six-speed transmission. A steel main frame and fully adjustable suspension help keep dry weight down to 237 pounds. Price: $5999Contact: www.kovemotousa.com SCALVINI FACTORY WORKS CONE PIPE Scalvini’s two-stroke Factory Works pipes are hand-assembled, cone by cone, for performance and style. Each cone is hand-cut, shaped and welded to exacting standards. Pipes feature a CNC-machined exhaust flange, Scalvini ID tag and double-walled mounting brackets. Available for most popular two-stroke models. Price: Contact for pricingContact: www.motomandistributing.com HYBRID MOTO RACK BY CCR SPORTS The Hybrid Moto Rack secures nearly any two-wheeled recreational vehicle. It mounts to pickup bulkheads, van partition walls, van seat bases or trailers using dedicated mounts. Constructed from 6063 aircraft-grade extruded aluminum with textured black powdercoat, it features heavy-duty tie-down loops, an exclusive X-nut fastening kit and Moto Vise wheel chocks with adjustable width. Price: $299.99 (free shipping)Contact: www.ccrsport.com MAXXIS MX-SI MOTOCROSS TIRES Developed with seven-time Supercross champion Jeremy McGrath, the all-new Maxxis MX-SI tires deliver the line’s best traction for soft terrain. The new tread pattern and compound provide consistent grip in rough conditions and under acceleration, while the redesigned front pattern improves lean-angle grip, stability and predictability. Price: $97 (80/100-21 front); $117 (120/80-19 rear)Contact: www.maxxis.com ALPINESTARS M3 YOUTH HELMET The all-new SM3 youth helmet from Alpinestars is anatomically engineered for younger riders and optimized for MX, enduro and off-road use. It incorporates technologies from Alpinestars’ adult helmets to deliver performance, protection and comfort. Available in multiple colorways, including limited editions. Price: $289.95Contact: www.alpinestars.com KOVE 800X PRO The new Kove 800X Pro aims to shake up the adventure-bike market with a blend of lightweight off-road capability and on-road comfort. It features a 799cc DOHC parallel-twin engine producing 95 horsepower and a curb weight of only 408 pounds. It includes a 5-gallon tank, three ride modes (Eco, Sport, Rain), ABS and Kayaba suspension. Price: $10,999Contact: www.kovemotousa.com PRO CIRCUIT WORK APRON Style and function meet in the Pro Circuit work apron. It protects clothes from oils and grime while offering front pockets for parts and tools. Featuring a white Pro Circuit checkered-flag design on durable black fabric, the apron includes adjustable waist and neck straps to fit most users comfortably. Price: $28.95Contact: www.procircuit.com 2026 FXR REVO ALPHA GEAR The FXR Revo series is built on years of athlete input and development. Revo gear delivers comfort, durability and freedom of movement for riders at every level. The Alpha collection refines that foundation with premium materials, race-proven fit and bold graphics. Price: $89.99 (jersey); $229.99 (pants)Contact: www.fxrracing.com MOLECULE MOTORSPORTS SKID PLATE Made in the USA, Molecule Motorsports skid plates are thermoformed from billet UHMW. This lightweight material has superior wear properties compared to aluminum and carbon steel and is self-lubricating, helping the bike slide over obstacles. Stainless hardware is included. An optional one-piece linkage guard with damper pad offers maximum protection. Available for most popular off-road models. Price: $129.99–$399.99Contact: www.moleculemoto.com FISCH MOTO YZ250 ELECTRIC STARTER Fisch Moto now offers an all-in-one bolt-on electric-start conversion kit for the Yamaha YZ250 (2003–2025) and YZ250X (2016–2025). Using the OEM flywheel, this kit lets riders start with the push of a button and eliminates the need for a kickstarter. It adds just 9.6 pounds including the battery. Price: $1090Contact: www.fischmoto.com JD JETTING FUEL-INJECTION TUNER Dyno- and field-tested, the JD Jetting Power Surge 6X fuel-injection tuner lets riders easily adjust fueling for changes in climate, race fuels or engine mods. It mounts to the bike and allows quick fuel adjustments—adding or subtracting fuel from the injection system in seconds. Price: $261.95Contact: www.jdjetting.com SCOTTS PERFORMANCE STABILIZER SYSTEM The Scotts steering stabilizer is a compact, fully adjustable hydraulic damper that mounts above the handlebar clamp. It helps control the left-to-right front-end movements known as “headshake.” Scotts offers kits for most popular dual-sport and adventure bikes. Price: Contact for pricingContact: www.scottsonline.com ODI NOMAD LOCK-ON GRIPS ODI’s Nomad lock-on grips use D3O vibration- and impact-absorbing material and were developed with off-road riders in mind. The medium-diameter grip uses finger-traction points so you can hold on with less effort, while the D3O material minimizes shock and vibration. Available in six color combos and made in the USA with a 100-percent slip-free guarantee. Price: $39.95Contact: www.odigrips.com GBRAKES PADS GBrakes’ 69, 70, 72, 75 and 76 Series pad compounds bring new levels of braking reliability and performance to dirt and dual-sport bikes. Made with NRS technology—a matrix of steel-bonded hooks that fuse the compound to the backing plate—they prevent separation, lifting edges and vibration. Free from nickel and copper. Price: $38Contact: www.gbrakes.com TREAD DOCTOR The Tread Doctor from Hardline Products is a heated tire-cutting tool that lets users cut new edges on worn knobs or groove a tire for custom patterns. It can extend tire life and give backyard tuners more control over traction. Price: $64.99–$89.99Contact: www.hardlineproducts.com FCP RACE CUPS Reversible headset cups—also known as offset steering races—from Factory Chassis Parts allow riders to rake in or rake out the front end, changing head-tube and fork angle by 20 minutes (1/3 degree). This can drastically improve handling and alter wheelbase and geometry. Used in SX and outdoor MX by riders like Freddie Noren, Bubba Pauli and Grant Harlan. Available for Kawasaki, Yamaha and Honda, with KTM-group models coming. Price: $589–$599Contact: www.fcpracing.com RIDE ENGINEERING Ride Engineering’s 23.5mm offset triple-clamp system for 2023–2026 KTM, Husqvarna and GasGas 125–450cc models is designed to improve overall handling and comfort through increased stability. It’s available with a one-piece anti-twist handlebar mount and in multiple color options. Price: $799 (triple clamp); $99 (bar mount)Contact: www.ride-engineering.com SIDI X POWER SC BOOTS The Sidi X Power SC boots are purpose-built for off-road use and crafted to handle tough terrain. They offer a unique combination of durability, comfort and advanced protection in a lightweight package. Available in five colorways and sizes from 4.5 to 15. Price: $399Contact: www.helmethouse.com SLAVENS RACING TWO-STROKE CYLINDER HEAD Slavens Racing two-stroke performance cylinder heads for KTM, Husqvarna and GasGas 250/300s are machined from solid 6061 T6 aluminum and offer improved performance, reliability and fuel economy. They’re one of the best bolt-on mods you can buy. Each complete head includes a cap with improved strength and factory-anodized appearance, plus a combustion-chamber insert that is interchangeable to tailor power delivery. Price: $320Contact: www.slavensracing.com The post The Ultimate 2026 Dirt Bike Holiday Gift Guide appeared first on Dirt Bike Magazine. Просмотреть полный текст статьи Цитата
