Since their inception over 65 years ago in 1957, Liqui Moly has been committed to innovation, growth and excellence in everything they do. We teamed up with the crew at Liqui Moly and a handful of other industry-leading companies to build this GasGas MC150.
1. Designed specifically for motocross use, the Mitas Terra Force MX SM front and rear tires feature a tread pattern and carcass for soft to intermediate terrain. The Terra Force MX line is a direct result of racing development done on the MXGP circuit.
2. The original Pro Circuit Works pipe and R-304 stainless steel Shorty silencer combination is designed to increase performance throughout the powerband.
3. WP Pro Components suspension, like the XACT Pro 8950 rear shock and XACT Pro 7548 spring fork featuring proprietary Cone Valve technology, are the components used by the GasGas factory race teams around the world.
4. Jeff Emig has redeveloped the popular ODI V2 lock-on grips with a medium-durometer compound; aggressive, tacky knurls; articulated, tall waffle pattern; and nine different colorway options.
5. Born from the needs of professional race teams like Star Racing Yamaha, the new Rekluse Apex is designed to provide a smooth and consistent lever pull, transfer more power to the rear wheel, and maximize durability, thanks to patented technology, including the Fixed-Pin hub, TorqDrive friction plates, and more.
6. The GasGas factory wheelset features CNC-machined, billet-aluminum, red-anodized hubs providing weight savings and increased strength. Also included are anodized spokes and nipples laced up to D.I.D DirtStar black rims.
7. Twin Air’s PowerFlow kits are designed to ensure a leak-proof, fool-proof fit with a rigid, lightweight, billet-aluminum cage and dual-stage air filter also included in each kit.
PBS_Caption1-copy_e-1024x609.jpgJared and the crew at Backyard Designs collaborated with the Dirt Bike staff to come up with a set of custom graphics that brought the entire build together and provide a clean, classic look. PBS_Caption2-copy_e-1024x496.jpgThe Grip Pro is a one-piece OEM replacement seat cover made from Seat Concepts’ high-grip wire gripper material. Designed for quick and easy installation, and features a pre-sewn front pocket to simplify alignment. Engineered for enhanced grip and upgraded style, the Grip Pro offers an alternative replacement without ribs to your original cover. PBS_Caption3-copy_e-1024x678.jpgTM Designworks’ FX rear chain guides feature a streamlined profile and an increased coverage of the swingarm mounting tabs. The guide also has replaceable wear pads, the Return Memory System and is available in multiple color options. PBS_Caption4-copy_e-1024x611.jpgComplementing the original Fasst Company Flexx handlebar is the recently released Low Bar, which is designed for the rider looking for the lowest possible overall bar height. At 68mm tall, the Low Bar perfectly complements our 92mm and 116mm bars. It’s ideal for offsetting added height from a damper or lowering your setup in general. PBS_Caption5-copy_e-1024x678.jpgFCP Racing engine mounts are designed to improve overall handling, and feature CNC-machined top mounts and titanium front-mount hardware. They’re used under the radar by many factory-level Supercross and off-road professional teams.
The post PROJECT BIKE SPOTLIGHT: LIQUI MOLY GASGAS MC150 appeared first on Dirt Bike Magazine.
