The world has changed. The windsock of technology has turned around and now shows a strong wind coming directly from China. Bikes like the Kove MX450 represent the next big thing in motocross. Nothing will change that; not tariffs, not politics, not attitudes.
Three years ago, Kove established itself in the rally world by becoming the first Chinese motorcycle to finish the Dakar Rally. Motocross is next on the agenda. The first shipment of production MX450s is already ashore in America with a price of $7999, which includes the current tariff of over 35 percent. That tax will almost certainly change in the future, but for right now, the price is set at almost $3000 less than mainstream 450 motocross bikes from Europe and Japan. What’s more significant is that the bike is legit. This is no untested knockoff. In its first incarnation, it’s already in the hunt.
quickshift comes as a standard feature
WHEN IS A KNOCKOFF NOT A KNOCKOFF?
We would love to be able to test the Kove without talking about past Chinese malfeasance, but that’s impossible. The motorcycle industry has suffered greatly from a flood of copycat brands that vanish overnight, leaving a wake of broken and unsupported products. Kove has been fighting an uphill battle against that reputation and making slow progress. The U.S. importer has been around for over 20 years with various brands and products, and has invested a great deal in customer support. That effort is already paying off in the rally bike segment, where social media comments from real-world owners are overwhelmingly positive.
The MX450 isn’t a knockoff of any specific motorcycle, but it wasn’t built in a vacuum. The motor has a very strong Honda vibe. It’s a single-overhead-cam four-valver. This motor was originally developed for the competition version of the rally bike and was tested in the Dakar Rally itself. To make it into a motocross bike, the engineers found more power and developed a new five-speed gearbox. The chassis isn’t quite like anything else currently on the market. If you want to go back a few years, you can see some influence from the last generation of two-stroke motocross bikes from Kawasaki. It uses a perimeter configuration made of steel. The people at the Kove factory originally saw this bike as a special edition, which is why it has a KYB fork, titanium footpegs, a titanium exhaust, and a number of parts that are machined from billet and anodized. The split triple clamps, in particular, are beautifully made and rival anything from Europe. The wheels, in fact, are from Europe. GLM supplies the rims, hubs and spokes from Italy. After some initial thought, the U.S. importer decided that the special edition would be the only version for the U.S. The rear suspension still uses a Chinese-made Yu-An shock, and it might be the only thing on the bike that can truly be called a knockoff. It’s very much like a Showa damper, and suspension tuners report that it will accept all the Race Tech components, like gold valves and bladder kits that were designed for Showa.
The brakes are made by Taisko and look like a cross between Brembo and Nissin items. Again, these are similar but not identical to existing parts. The front brake pads are proprietary Taisko items, while the rear caliper is close enough to a Nissin to accept Honda brake pads. The rear sprocket, not surprisingly, uses a KTM bolt pattern, but the wheel itself is different. Another perk that comes as standard equipment is the map switch. This allows you to switch between two maps, and also offers launch assist and a lap timer. It does not have a Quickshift button, but the bike does have Quickshift. It’s always on unless you disconnect a wire.
Perhaps the best indication that the new Kove is no knockoff is the weight. On our scale, it weighs 234 pounds without gas. That means it’s lighter than a Honda, Kawasaki and Suzuki. Copies are never lighter than the original.
the msrp for the 2026
The MSRP for the 2026 Kove MX450 is $7999. That includes the 35-percent tariff.
A NEW BREED
We first rode a prototype of this bike last summer. It had the latest motocross chassis, but the motor was lifted straight from the rally bike. We knew that the gearing was going to be super tall and the mapping was a work in progress, but we couldn’t resist the offer. It was just good enough to serve notice that the production bike was going to be something special and like no other Chinese motorcycle—ever.
That prediction turned out to be true. The two biggest issues we had with the prototype were gearing and mapping. The bike was geared so tall that it never made it out of third gear on Glen Helen’s national track. That combined with sketchy mapping to present a stall threat in every turn. Kove has made progress on both fronts. With motocross-appropriate gearing, the production Kove motor is revealed to be a powerhouse. It produces excellent torque that smoothly transitions to very impressive mid-range. Peak power is somewhere in the same neighborhood as a Honda CRF450R or a Kawasaki KX450. For a seat-of-the-pants reference, we used the Honda CRF450R tested in this issue. Roll-on drag races demonstrate that the Honda is stronger below 7000 rpm, but only by a small margin. That’s forgivable; the Honda is stronger than any motocross bike in that range. On top, the two bikes are similar, which means they are a half step behind the Austrian bikes and the Yamaha. Again, that’s forgivable, considering that overkill is a common complaint with those bikes. Modern 450s have long since withdrawn from the peakhorsepower contest and instead concentrate on power delivery.
On the mapping front, Kove has made huge strides since our experience with the prototype. It doesn’t stall in tight turns, but it does hiccup and burp. It’s more of an auditory issue than a performance one. Both maps have similar issues, so we don’t know if it’s easily solved. As of recently, the Kove importer has been granted the capability to make its own maps, but their base of operations is around 5000 feet in the mountains of Utah. There might be updates forthcoming, but for now, how the bike comes is how the bike comes. Along the same lines, the exhaust note is very loud. The thought of replacing that beautiful titanium exhaust would be a heart breaker, so the first stop would have to be repacking with quality material.
a version of this motorA version of this motor first saw service in the competition version of the rally bike. Now, it has a five-speed gearbox and motocross tuning.
SUSPENSION SUSPENSE
The people at KYB probably had a hand in the final suspension settings. The fork is excellent. It’s set up well for amateur-level motocross with riders weighing around 170 pounds. We know from experience that good suspension is the end product of both componentry and frame design, so we have to believe that the engineers at Kove know what they are doing. The front end never delivers that harsh feel that’s so common with first-year motocross bikes. The rear end is a little more mysterious. It’s far too stiff for the aforementioned amateur rider. It’s as if the rear suspension was designed for Supercross and the front end was for off-road. All we could do was back off the settings, but we used up all the spring-preload adjustment to get reasonable sag for our test riders—around 105mm for a 180-pound rider. Again, we know that the shock internals are similar to Showa parts, but most of our problems would probably be solved with a softer spring.
Despite that, the overall handling was good. You might think that stiff rear suspension would result in headshake and instability. That wasn’t the case. The Kove is predictable and goes dead straight. If we had to compare it to something more mainstream, we would say it’s similar to a Kawasaki. It turns well, and even the CST tires work well just about everywhere.
WHERE TO GO FROM HERE
So the Kove MX450 isn’t a perfectly finished product, but no bike is. Everyone who buys a new MX bike is buying a project. Sometimes you get lucky and don’t have to pay for suspension work, wheels and other parts. Not always, though. We would guess that Kove owners will be the kind of riders who like to tinker, experiment and take a chance. The best thing about buying a bike that sells for $7999 is that you have a big budget to make it your own.
The post 2026 KOVE MX450 REVIEW appeared first on Dirt Bike Magazine.
